Converted IAP175 to controller based But only Air Monitor
We have IAP-175 Outdoor AP we converted AP to as  working with  Controller based . But We cannot see this AP on the normal menu
That AP only showing us AIR monitor. we need help .
Re: Converted IAP175 to controller based But only Air Monitor
Have you had a chance to check the RF radio profiles and see if it is configure as a Air Monitor?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
i checked this configuration . and it is ap mode.is this problem about  regulatory domain ?
thnk you
You are right , see this post :
http://community.arubanetworks.com/t5/Outdoor-WLAN-and-Mesh/AP-175-configuration-bg-is-not-working/m-p/76892#M232
Thank you
Victor Fabian
