Converting an AP 365 to campus ap on controller
I purchased some Aruba 365 outdoor APs. When I try to provision one the controller is not seeing it. I had this issue before with some 105 APs and realized that they were IAPs and needed to be converted the campus APs. I would do so by connecting to the SSID "instant" then going to the URL http://instant.arubanetworks.com/ to start the conversion. This AP(365) had a SSID of 'configureme[mac address]".
I connected to this SSID then tried to go to http://instant.arubanetworks.com but it's not working. Is there another URL that I'm supposed to use? Any help would be appreciated. -Tony
Re: Converting an AP 365 to campus ap on controller
The AP365 is one of the first to ship with a Unified AP Image.  Please see the Unified AP startup documentation here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/24267/Default.aspx
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
