Correct PoE injector for 205
What is the correct Watts, Volts and Amp injector needed for the 205?
I have a 55V 0.6A that our supplier gave us with the 205, it works but the 205 unit gets extremly hot.
Re: Correct PoE injector for 205
Hey, according to the AP205 datasheet Aruba recommends the following POE injector.
JW627A : PD-3501G-AC 15.4W 802.3af PoE 10/100/1000Base-T Ethernet Midspan Injector
Which one are you using?
If my post addresses your query, give kudos:)
If you are using a POE injector, it MUST be certified and rated for 802.3af/at. If you are using a power supply (power conenctor, not in-line with ethernet) then it should not be used on that AP.
Jerrod Howard
