Could Mobile IP cause connection issues with Wireless Clients?
We're having some problems with connectivity drops (severely intermittent pings at random as an example) with some devices and while debugging I noticed some messages about IP Mobility, so I thought I'd try disabling Mobile IP and check out the results. So far, the devices in question haven't had any issues (famous last words?).
Background -
AP68 and AP61.
802.11g clients using WPA-PSK.
Most of the config is using default profiles.
I can give more specifics if required, but all I'm after really is an expert point of view, could disabling Mobile IP in the VAP give any benefit to a client in bridge forwarding mode?
Re: Could Mobile IP cause connection issues with Wireless Clients?
Is there any need for IP Mobility? How many controllers, APs, and VLANs?
Zach Jennings
There's no need to have it enabled, there's no requirement for devices to cross subnets/vlans so I can disable it. We have a single M3 module, the vlans are local to the location of the AP (assume 1 AP per geographical location and approx 200 locations) and all in bridge mode. So we have the same vlan number at each site. Is it recommended to disable it if it's not required? If so, for what reason?
Adam@CCS wrote:
It does not play a part in bridged mode.
Thanks all for the replies -
That's exactly the answer I was expecting, so I can't explain the improvement. I'll continue to monitor as I suppose it could just be a fluke, but I think going forward I'll disable Mobile IP on bridge mode VAPs (even if it is just a placebo!)
I've just been looking to see if there's a new release of OS5 and come across this in the release notes for 5.0.4.4
Bug ID Description
63808,
64086
In some cases, CPSEC AP’s and RAP’s configured with a bridge VAP might experience repeated
crashes due to a kernel panic. This kernel panic is caused by the code that handles client mobility
in bridge mode.
Workaround:
None.
I'm a bit confused by the terminolgy in use sometimes, is this/could this be related to my original question?
Adam@CCS wrote:
Bug ID Description
63808,
64086
in bridge mode.
Workaround:
None.
It very well could be.  Please open a case so that it can be confirmed in your specific case.
Will do, thanks.
