Coverage of AP 274 with NT-3x3-D100 90 degrees antenna
Anyone know how far this antenna can go giving good signal to abg clients?
Would it give good signal to clients at 100m  far from it?
Cheers
Carlos
Alternetworks Corp
Re: Coverage of AP 274 with NT-3x3-D100 90 degrees antenna
I've heard about 30 Mbps on a distance of 90 meters but if some one have more exact data or confirmation of it, it will be nice to see them
We have testing data using the 277 where an unmodified macbookpro with VHT80 supported over 300Mbps of TCP thorughput at 600m. However, using VHT80 is not really tenable. However, at 30m, it should be at near MAX speed for the band/channel-width. 100m with the D100 should generate at least 100Mbps for HT40, if not more. The 'it depends' comes in to play as noise floor, interference, device type and orientation (going through bodies, is it overhead, any foliage, etc all come in to play).
Jerrod Howard
