cdj
Contributor I
Creating a Whitelist for Devices (non-aruba)
We're currently running 6.3.1.9 FIPS on two 6000M3 controllers, is it possible for us to configure a whitelist for specific devices (non-aruba) ? I'm assuming we're going to have to create a new SSID so these devices can have access to our internal (employee) network.
Re: Creating a Whitelist for Devices (non-aruba)
What type of encryption will these devices be using?  If you are using FIPS, I am assuming you want the additional security.  If that's the case, I hope you are able to use something stronger than mac authentication for your devices.....
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
