Occasional Contributor I
Creating two PTP links on one Radio - AP175
Is it possible to create multiple PTP links on one Radio of Outdoor AP-175 using directional antennas? If yes, what is the impact of this design on the performance of the access point.
Shahryar Ali
Product Engineer- ICT
ACMA, CCNA (R&S) , CloudU
Aruba
Re: Creating two PTP links on one Radio - AP175
this is not possible with AP-175.  Each radio in on a separate band, and only one radio can be meshed.
MeshOS does support this, using separate channels on each radio to avoid any performance penalty.
-cl
I do not understand. Cant we create two PTP links on the same channel in different directions using directional antennas?
Shahryar Ali
Aruba
No.   The radios in AP-175 cannot be on the same frequency band.  One is fixed to 2.4GHz and the other to 5GHz.
If you need to go 2 different directions then you must use an omni antenna, which will reduce your overall range.
-cl
