Occasional Contributor I
Custom Painted AP's
Is it possible to custom paint Aruba indoor AP's (either Factory custom color matched to RAL number, or field painted by installer)?
Also, less critical but we were asked by an architect if it's possible to disable any LED lights visible on the AP? (Although I'm not certain if the current Aruba AP WAP's have any visible LED lights)
Re: Custom Painted AP's
You can order plastic covers for the APs which have a printable surface.
You can disable the LEDs in the ap system-profile for a whole group or just a single AP.
Tim Cappalli | Aruba Security
Hi that looks like a good solution, I'm assuming you're refering to the Oberon paintable plastic covers that cover the entire WAP from view? (Didn't see any on the Aruba website, but Oberon is who came up when I Googled the term)
No, Aruba has snap-on covers. The SKU is AP-XYZ-CVR-20.
The XYZ varies by AP family.
Hi Tim,
Is this also the case for AP315? Any chance you can give me the part# for the snap-on cover? It's not in the data sheet it appears.
Thanks!
Please see the instruction sheet  here:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Method/attachment/Default.aspx?EntryId=23789
The datasheet for the 315:http://www.arubanetworks.com/assets/ds/DS_AP310Series.pdf
Aruba
JW827A: Aruba 315-CVR-20 20-pk for AP-315 with Holes for LED Indicators White Non-glossy Snap-on Covers
/Onno
