DDS (Multicast) is not working
  • 1.  DDS (Multicast) is not working
    Posted Mar 19, 2014 08:19 PM
    I'm trying to run an application based on Data Dastribution Service in my network. Currently a destination can't connect to the multicast group and receive any messages. BCMC (Broadcast-Multicast) Optimization and Drop broadcast are disabled on controller. Do you have any ideas what to check?
    PS: If I switch to a low cost D-Link or any other the application works.
    PSS: I'm running 3600 controller with 6.3.1.3 os and AP-105 access points.
    #3600
  • 2.  RE: DDS (Multicast) is not working
    Posted Mar 19, 2014 11:27 PM
    Are you running ip igmp proxy or snooping on that VLAN ?
  • 3.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 01:24 PM
    I've tried to check only IGMP, then IGMP Snooping, and finally IGMP proxy. Nothing changed. Also "show ip igmp" is empty.
  • 4.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 01:35 PM
    What is the role for your users on that wireless network?  What is being allowed?
  • 5.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 02:34 PM
    Currently I've disabled any authentication on the lab network. User roles in default state. Should I change something in that area?
  • 6.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 02:35 PM
    When you say default state, what role does the wireless user get?
  • 7.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 02:41 PM
    "Monitoring>Controller>Clients" page shows User Role "logon".
  • 8.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 02:44 PM
    The logon role will be blocking your multicast traffic.  You need to change the initial role in the aaa profile to "authenticated".
  • 9.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 04:54 PM
    Changed to authenticated. Still nothing. Do you have any other ideas?
    Update:  Now controller shows a group:
    (Aruba3600-US) #show ip igmp group
    IGMP Group Table
    Group Members
    239.255.0.1 1
    Total Groups: 1
  • 10.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 04:56 PM
    Is the host sending the traffic on the same vlan as the clients or a different VLAN? You might want to open a TAC case in parallel...
  • 11.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 05:11 PM
    It's the same VLAN 1 interface.
  • 12.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 05:29 PM
    Here is the statistics:
    IGMP Statistics
    Name Value
    received-total366
    received-queries0
    received-v1-reports0
    received-v2-reports133
    received-leaves49
    received-unknown-types184
    len-errors0
    checksum-errors0
    not-vlan-dr0
    transmitted-queries11
    forwarded9
    non-conforming-igmp0
  • 13.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 05:31 PM
    If it is in the same vlan and the firewall policy on the client role is not blocking anything. IGMP should not be involved
  • 14.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 05:51 PM
    Curernt policy is:
    authenticatedra-guard/,allowall/,v6-allowall/
  • 15.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 05:55 PM
    On the commandline, you should be able to type "show datapath session table <ip address of multicast device>" to see any traffic that is seen by the controller.
  • 16.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:02 PM
    172.16.0.247 is my source and 246 is destination:
    (Aruba3600-US) #show datapath session table 172.16.0.247
    Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes Flags
    172.16.0.247 172.16.0.255 17 138 138 0/0 0 24 1 tunnel 12 8 1 229 FTC
    172.16.0.255 172.16.0.247 17 138 138 0/0 0 24 1 tunnel 12 8 0 0 FY
    172.16.0.247 239.255.0.1 17 50954 7400 0/0 0 24 1 tunnel 12 19 0 0 FTC
    (Aruba3600-US) #show datapath session table 172.16.0.246
    172.16.0.246 172.16.0.247 17 52600 7410 0/0 0 24 0 tunnel 12 2 0 0 FTC
    172.16.0.247 172.16.0.246 17 7410 52600 0/0 0 24 0 tunnel 12 2 0 0 FY
    172.16.0.246 239.255.0.1 17 52601 7400 0/0 0 24 0 tunnel 12 2 2 1568 FTC
  • 17.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:08 PM
    Type "show wlan virtual-ap" to find your virtual AP, then type "show vlan virtual-ap <name of virtual ap>" so we can see the properties of it.
  • 18.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:10 PM
    Here is it:
    (Aruba3600-US) #show wlan virtual-ap
    Virtual AP profile List
    Name References Profile Status
    default 1
    Total:1
    (Aruba3600-US) #show wlan virtual-ap default
    Virtual AP profile "default"
    Parameter Value
    AAA Profile default
    802.11K Profile default
    Hotspot 2.0 Profile default
    SSID Profile default
    Virtual AP enable Enabled
    VLAN 1
    Forward mode tunnel
    Allowed band g
    Band Steering Disabled
    Steering Mode prefer-5ghz
    Dynamic Multicast Optimization (DMO) Disabled
    Dynamic Multicast Optimization (DMO) Threshold 6
    Drop Broadcast and Multicast Disabled
    Convert Broadcast ARP requests to unicast Disabled
    Authentication Failure Blacklist Time 3600 sec
    Deny inter user traffic Disabled
    Deny time range N/A
    DoS Prevention Disabled
    HA Discovery on-association Enabled
    Mobile IP Enabled
    Preserve Client VLAN Disabled
    QinQ Outer VLAN 0
    Remote-AP Operation standard
    Station Blacklisting Enabled
    Strict Compliance Disabled
    VLAN Mobility Disabled
    FDB Update on Assoc Disabled
    WMM Traffic Management Profile N/A
  • 19.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:14 PM
    What is the result of "show aaa profile default"?
  • 20.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:17 PM
    I've changed initial role from logon to authenticated:
    (Aruba3600-US) #show aaa profile default
    AAA Profile "default"
    Parameter Value
    Initial role authenticated
    MAC Authentication Profile N/A
    MAC Authentication Default Role guest
    MAC Authentication Server Group default
    802.1X Authentication Profile N/A
    802.1X Authentication Default Role guest
    802.1X Authentication Server Group N/A
    L2 Authentication Fail Through Disabled
    User idle timeout N/A
    RADIUS Accounting Server Group N/A
    RADIUS Interim Accounting Disabled
    XML API server N/A
    RFC 3576 server N/A
    User derivation rules N/A
    Wired to Wireless Roaming Enabled
    SIP authentication role N/A
    Device Type Classification Enabled
    Enforce DHCP Disabled
  • 21.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:18 PM
    If all the ports on the controller are on VLAN 1, you can plug a laptop into another port on the controller to see if you see the multicast traffic.
  • 22.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 06:45 PM
    It works!!! Currently I have a laptop (source) connected to controller via RJ45 and a laptop (destination) connected to AP via WiFi.
    The next step is to define why WiFi to WiFi has 50% transmissions loss.
  • 23.  RE: DDS (Multicast) is not working
    Posted Mar 20, 2014 08:34 PM
    50% transmission loss?  Is that application optimized for wireless or is it supposed to be running on wired?
  • 24.  RE: DDS (Multicast) is not working
    Posted Mar 21, 2014 10:31 AM
    Forwarded my findings to dev team. I will update the topic tomorrow with the latest results. Thanks.
