DFS Channels - Advertised H Enabled etc
Maybe i'm doing something wrong, however, enabling all dfs channels and channel groups, I only see Ap's using channel very few of the DFS channels in the DFS range.  All AP 205 and a few AP 275's...  Thoughts, suggestions?
(Aruba7210) #show ap regulatory-domain-profile WithDFS
Regulatory Domain profile "WithDFS"
Parameter Value
Country Code US
Valid 802.11g channel 1
Valid 802.11g channel 6
Valid 802.11g channel 11
Valid 802.11a channel 36
Valid 802.11a channel 40
Valid 802.11a channel 44
Valid 802.11a channel 48
Valid 802.11a channel 52
Valid 802.11a channel 56
Valid 802.11a channel 60
Valid 802.11a channel 64
Valid 802.11a channel 100
Valid 802.11a channel 104
Valid 802.11a channel 108
Valid 802.11a channel 112
Valid 802.11a channel 116
Valid 802.11a channel 132
Valid 802.11a channel 136
Valid 802.11a channel 140
Valid 802.11a channel 144
Valid 802.11a channel 149
Valid 802.11a channel 153
Valid 802.11a channel 157
Valid 802.11a channel 161
Valid 802.11a channel 165
Valid 802.11g 40MHz channel pair 1-5
Valid 802.11g 40MHz channel pair 7-11
Valid 802.11a 40MHz channel pair 36-40
Valid 802.11a 40MHz channel pair 44-48
Valid 802.11a 40MHz channel pair 52-56
Valid 802.11a 40MHz channel pair 60-64
Valid 802.11a 40MHz channel pair 100-104
Valid 802.11a 40MHz channel pair 108-112
Valid 802.11a 40MHz channel pair 132-136
Valid 802.11a 40MHz channel pair 140-144
Valid 802.11a 40MHz channel pair 149-153
Valid 802.11a 40MHz channel pair 157-161
Valid 802.11a 80MHz channel group 36-48
Valid 802.11a 80MHz channel group 52-64
Valid 802.11a 80MHz channel group 100-112
Valid 802.11a 80MHz channel group 132-144
Valid 802.11a 80MHz channel group 149-161
rf dot11a-radio-profile "LHS_A_radioprofile"
dot11h
arm-profile "LHS_A_armprofile"
Re: DFS Channels - Advertised H Enabled etc
How many access points?
What channel width are you using?
It takes a great deal of time to scan extra channels to assign them. For an AP to use dfs channels it cannot be just a little better...it must be a certain margin better than the channel that it is currently on.
118 AP 205's, 1 in classrooms, commons areas, gyms , etc.. New High School.   Channel width is default.
If the ap is happy with its current channel, there is no reason to choose a dfsmall channel.
Understood... i had anticipated a channel seperating similar to arm and standard 5Ghz selection.  If i can see an AP on 1 dfs channel I can confirm its working.  Thanks
