Super Contributor II
DFS with 802.11ac
Hi All,
I'm looking for some advice in relation to using DFS with VHT80 channel groups.
If a DFS event detects radar on a channel which is a member of a VHT80 group, does the whole group get excluded from operation or will the radios just switch to VHT40/20 (whatever is appropriate)?
Also is DFS exclusion of a  channel a time based process (i.e. will ARM allow reuse of that channel after a predetermined period of no radar detection ) or does it exclude the channel permanently until manually overridden?
Scott
Re: DFS with 802.11ac
It will switch to a new non-dfs 80 Mhz channel block available , the APs will inform all the devices about the change (which take approximately 10 seconds)
It will reuse those channels after 30 minutes if there's no radar detection
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks Victor, you're always so quick to respond!
