Frequent Contributor I
DHCP Error on 7200 Controller
I have about 14 new 7200 controllers that I'm installing. Each device will be a local controller in a building LAN. Each one will have 3 DHCP pools. The pools are built exactly the same on each controller. I have completed the configuration and installation of 2 controllers.
While adding the DHCP pools on the 3rd controller, I got the strange error which is attached. Can someone take a look and let me know what may be causing the error. You'll see that the pool is created and all info saved except the network address and its mask. It remains 0.0.0.0 0.0.0.0. When I attept to change it, I get the attached error.
Thanks for your help,
Re: DHCP Error on 7200 Controller
If you remove the pool and re-add it, do you still get the error? Is it only when modifying the existing?
Tim Cappalli | Aruba Security
If happened during the original creation.
I am out of the office for the rest of today but will remove and attempt to re-add first thing tomorrow.
Thank you,
Aruba
The 7210 can serve a maximum of 5120 DHCP addresses.   You already have your Student-WiFi pool that has 3831 addresses.  Your new pool has 3583; which exceeds the 5120 supported leases on the 7210.
From the 6.3 release notes:
You can also run show ip dhcp statistics to see a table of pools and the number of leases.
AMFX | ACCX | ACDX | ACMX
I underst what you're saying but is there a reason the first 2 controllers worked without a hitch???
Aruba
Are they all 7210s?  Were they upgraded to 6.3 after the DHCP scopes were created?    If they were, they'd still be present, but would still be capped by the 5120 number.
Run the following on one of the other controllers and share the result:
show ip dhcp database
They are all 7210s.
I will run the commands and post them when I get back to work tomorrow.
Thanks for the info!!!
What you will notice Mark is that you will see that the other pools will be 0 available addresses.
With 6.3 you are limited in terms of on controller DHCP. You will need to use an external DHCP server in your case.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
You were correct. It allowed me to add the pool in the previous controller. However, they are not all truely avilable.
Thanks for your help!!!!
(MCHS-Aruba) #show ip dhcp statistics
DHCPv4 enabled; DHCPv6 disabled
DHCP Pools
Network Name Type Active Configured leases Active leases Free leases Expired leases Abandoned leases
Staff v4 Yes 3583 0 3583 0 0
Access-Points v4 Yes 249 57 192 0 0
Students v4 Yes 3583 15 3568 0 0
Current leases 7415
Total leases 5120
WARNING: DHCP is oversubscribed; You may want to exclude unused address ranges
NOTE: To make a DHCPv6 pool active, ensure that the pool name is added in vlan interface
(MCHS-Aruba) #
