DHCP HELPER NOT WORKING
HI ,
  I have my controller on vlan 100 connected directly to office core switch, DHCP server is connected to site office core switch. MPLS connectivity is there between core switches. We are able to reach from controller to dhcp server. vlan 10 has been configured on controller, assigned a ipaddress on vlan 10 and dhcp helper is configured. Clients are not able to get ipaddress:(
INTERNAL DHCP SERVER FOR PARTICULAR VLAN
HI,
 i have configured dhcp server on aruba, it releases ipaddress for different vlan randomly. how can we specify different dhcp scope for specific vlan.
Re: INTERNAL DHCP SERVER FOR PARTICULAR VLAN
Do the following  :
- create a Layer2 VLAN : VLAN 10
- then create an SVI
 interface vlan 10
ip address 10.10.10.1 255.255.255.0
- Apply this VLAN 10 under the Virtual AP
ip dhcp pool TEST-DHCP-POOL1
default-router 10.10.10.1
dns-server 8.8.8.8
lease 0 1 0 0
network 10.10.10.0 255.255.255.0
Thank you
Victor Fabian
Lead Mobility Architect @WEI
hi victor,
    thanks for your reply, i tried it.. where can we add the specific route for vlan.
Super Contributor II
What do you mean by specific route for VLAN ? you can configure destination based routing under configuration and IP route tab.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
