DHCP Option 82 Sub Option 2
Has anyone used the dhcp option 82 before ?
We are trying to enable the option 82 in the controller with MAC+ESSID.
When we use wireshark to view the dhcp request, it seems like the request is going to Sub Option 1 instead of Sub Option 2 as specified in the rfc3046.
The Sub Option 2 in the controller enabled is only sending SSID in the Agent Remote ID instead of SSID+MAC.
Can anyone help verify if Aruba dhcp option 82 support Sub Option 2 ?
Regards.
Raymond.
Regular Contributor I
Re: DHCP Option 82 Sub Option 2
I see there is a option to set either Mac or mac essid. But, i dont know what is the purpose of it.
By the way i was looking at the rfc, that you mentioned http://tools.ietf.org/html/rfc3046
which section mention about the sub-option1 and sub-option2
