DHCP Relay - controller capacity
We are attempting to isolate our user device MACs from our core network.  To faciliate this, we would like to add a layer 3 interface to every user data network and perform DHCP Relay at that point.  My question is:  what is the controller's capacity to handle DHCP Relay?
Our configuration currently looks like:
2 x 7240s running in master / master via VRRP, ArubaOS
12,000 unique concurrent devices
Approximately 500,000 DHCP Requests / day
Thanks for any insight,
Frequent Contributor II
Re: DHCP Relay - controller capacity
I doubt engineering has tested this. If they have numbers it would be real world at a customer site.
I do however have a customer running 7240's with 8-9K unique devices and dhcp relay running on each van without issue. I would start with a baseline of your controllers then add a few DHCP helpers vlans at a time and keep track of the load/processes.
David Dipert
Thanks for the reply with your experience.  The sizing you've seen lets me know the controllers shouldn't be an issue.
