DHCP ip address not allocated
I have 2 WLANs :
1)WLAN naik_open_vlan_10 with VLAN 10 Employee VLAN
2)WLAN naik_open_all_vlan VLAN 1 MgmtVLAN
My 1) does not work i.e. when user with mac address 7c:11:be:6d:a0:56 tries to associate it does not get DHCP allocated ip address.
My 2) works fine though .
DHCP server is external Win2008
Please see logs below :
Re: DHCP ip address not allocated
Where are your VLAN interfaces? In the controller or upstream?
Sent from my BlackBerry Z10
Tim Cappalli | Aruba Security
Why is VLAN 10 and 1 handing out IPs on the same scope ?
Controller Log ,Good Example ,(WLAN naik_open_all_vlan VLAN 1 MgmtVLAN )
MAC=7c:11:be:6d:a0:56,IP=10.254.1.106
Controller Log ,Bad Example (WLAN naik_open_vlan_10 with VLAN 10 Employee VLAN)
Aug 1 19:46:01 :522050:  <INFO> |authmgr|  MAC=7c:11:be:6d:a0:56,IP=10.254.1.106
Can you do a show arp | include <devicemac> on the controller ?
And you please confirm the DHCP configuration
Also do a show trunk and show vlan on the controller to make sure the VLAN is active and up/up and do the same on the interface of the upstream switch
Thank you
Victor Fabian
Lead Mobility Architect @WEI
(MC1) (config) #show arp Protocol Address Hardware Address Interface
Internet 10.254.1.101 00:1A:1E:C0:BD:E6 vlan1
Internet 10.254.1.1 00:0B:86:63:BA:10 vlan1
Internet 10.254.1.103 00:0B:86:66:BD:3E vlan1
Confirm what on DHCP configuration ?
 Also checked the trunk
(MC1) # show trunk
Trunk Port Table
Port Vlans Allowed Vlans Active Native Vlan
FE1/4 ALL 1,10-11 1
(MC1) #show interface fastethernet 1/4 switchport   -> to Switch
Switchport: Enabled
Administrative mode: trunk
Operational mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (Default)
Trunking Vlans Enabled: ALL
Trunking Vlans Active: 1,10-11
Below are Switch confguration
(Switch_Naik) (config) #show interface fastethernet 1/7 switchport -> to DHCP Server
Switchport: Enabled
(Switch_Naik) (config) #show interface fastethernet 1/4 switchport ->To MC1
Switchport: Enabled
Aruba
to understand this better, can you share the following with us:
show vlan
show ip interface brief
show trunk you have already shown this
full results on both networks of the following:
logging level debug networking subcat dhcp
Attempt to connect to First Network
show log network | include <MAC>
Attempt to connec tot Second Network
After:
no logging level debug networking subcat dhcp
AMFX | ACCX | ACDX | ACMX
VLAN interfaces are  on the switch with ip address set
(Switch_Naik) (config) #show ip interface brief
Interface IP Address / IP Netmask Admin Protocol
vlan 1 10.254.1.1 / 255.255.255.0 up up
vlan 10 10.254.10.1 / 255.255.255.0 up up
vlan 11 10.254.11.1 / 255.255.255.0 up up
loopback unassigned / unassigned up up
mgmt unassigned / unassigned down down
(Switch_Naik) (config) #show vlan
VLAN CONFIGURATION
VLAN Description Ports AAA Profile
1 Default FE1/0-5 FE1/7 GE1/8 Pc0-7 N/A
10 VLAN0010 FE1/4-5 FE1/7 N/A
11 VLAN0011 FE1/4-5 FE1/7 N/A
Aruba
To clarify, please run the requested commands from the MC, not the switch.
What VLAN is the DHCP server on?   Do you have anything setup to forward DHCP requests for VLAN 10 to this IP?  Either on the controller or the switch?
Please see attached file
(Switch_Naik) (config-subif)#show interface vlan 10
VLAN10 is up line protocol is up
Hardware is CPU Interface, Interface address is 00:0B:86:63:BA:10 (bia 00:0B:86:63:BA:10)
Description: 802.1Q VLAN
Internet address is 10.254.10.1 255.255.255.0
Routing interface is enable, Forwarding mode is enable
Directed broadcast is disabled, BCMC Optimization disabled ProxyARP enable Suppress ARP enable
Proxy Arp is enabled for the Interface
IP Helper Addresses Configured on this Interface:
10.254.1.21
VLAN 10 has ip helper configured as seen above .
DHCP Server is trunk connected to Swicth as seen in out put in this thread (
show interface fastethernet 1/7 switchport)
