DHCP not working
  • 1.  DHCP not working
    Posted May 24, 2017 04:21 AM
    I'm trying to configure a captive portal. At the moment, DHCP isn't working at all though. If a user connects their device to the open SSID, they don't get any IP address assigned. It's not even making it to the captive portal page. I'm trying to assign the IPs via the internal DHCP server. Here is my configuration:
    aaa authentication captive-portal Example-cp
    default-role Example-user
    user-logon
    no guest-logon
    server-group CP-Test
    user-role Example-user
    vlan 25
    captive-portal "Example-cp"
    access-list session global-sacl
    access-list session apprf-Example-user-sacl
    access-list session allowall
    aaa profile Example-aaa
    initial-role authenticated
    wlan ssid-profile Example-ssid
    essid "Example-CP"
    opmode opensystem
    wlan virtual-ap Example-vap
    vlan 25
    aaa-profile Example-aaa
    vlan 25
    interface vlan 25
    ip address 192.168.75.1 255.255.255.0
    no ip routing
    ip nat inside
    ip dhcp pool vlan25
    network 192.168.75.0 255.255.255.0
    default-router 192.168.75.1
    dns-server 8.8.8.8 8.8.8.9
    domain-name example.com
    authoritative
    ip access-list session allowall
    any any any permit
  • 2.  RE: DHCP not working
    Posted May 24, 2017 06:34 AM
    It is hard to tell what is wrong, because you picked certain portions of the configurtion to display, but it is not clear how they are related.
    You should associate a client to the SSID, let it fail or get a .169 address and find out what role it is in.  After that, give us the output of "show rights <role>"
  • 3.  RE: DHCP not working
    Posted May 30, 2017 05:00 PM
    Thanks for the response Colin.
    I'm sorry this has taken so long. It seems like it is assigning the VLAN correctly. I would happily post the configuration, but it's quite large as it contains a few exprimental setups at the moment. Is there anymore of the configuration you'd need me to post?
    (device) #show rights Example-user
    Derived Role = 'Example-user'
    Up BW:No Limit   Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Assigned VLAN = 25
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Web Content Classification: Enabled
    ACL Number = 102/0
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Captive Portal profile = Example-cp
  • 4.  RE: DHCP not working
    Posted May 31, 2017 07:25 AM
    Adding to Colin's earlier post, the following CLI data would be helpful to see what is the actual client status when DHCP is not working:
    # check to ensure the client's MAC is learned in the VLAN
    show datapath bridge | inc <client MAC in CAPS>
    # check which role and VLAN the client has
    show user-table verbose | inc <client mac>
    # check the rights of the role
    show rights <rolename>
    # this will show which rules are being hit
    show acl hits user-role <rolename>
    It sounds like the bit we're missing is does the user land in the  Example-user role, and what does that role allow.
  • 5.  RE: DHCP not working
    Posted Jun 02, 2017 03:56 AM
    Thanks Shawn for your assistance. I discovered the solution on my own.
    I had two DHCP pools configured with more than 255 addresses. The Aruba 620 (running on 6.4.2.12) can not have more than 255 addresses assigned to DHCP pools and thus was not assigning more addresses to my new VLAN.
    I noticed this when I tried to delete all the configuration and re-add it. I got this error:
    (device) (config) #ip dhcp pool vlan25
    (device) (config-dhcp)# network 192.168.75.0 255.255.255.0
    Failed to add pool vlan7 which has more than 256 addresses. Maximum addresses configurable is 256.
    To fix this, I had to exclude some IP addresses from the existing DHCP range and exclude some from this range using the "ip dhcp excluded-address" command.
    Helpful: http://community.arubanetworks.com/t5/Wireless-Access/620-AOS-6-3-1-2-Failed-to-add-DHCP-pool-due-to-address-ranges/td-p/138267
