DHCP on Aruba 3810 Switch
What is the capacity of the DHCP server on a 3810 switch. Is there a limit on address leases allowed. Is there a limit on DHCP scope size? Would this be a recommended DHCP solution for a large scale (thousands of wireless devices) deployment?
M
Frequent Contributor I
Re: DHCP on Aruba 3810 Switch
For lease time, it can be configured unlimited or you need.
I think the switch can be served over a thousand of client.
Thank you,
Ratchapas S.
