NTH
DHCP problems on version 8.0.1
Hello
I have been trying to migrate our working config from version 6.5.x.x to AOS 8.0.1 in a virtual MM and a spare controller. We did not use the migration tool, as that was too limited in how we wanted our new setup to be designed.
I cannot get external DHCP to work (the DHCP server is the same as the 6.5 is running on). Only when I use the internal DHCP does my clients (using a 335 AP) get a DHCP adresses. However, the limit of 8k adresses makes this unusable for us.
I am getting the following log entry when I enable external DHCP:
PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 0 Sequence Num is 32310
Re: DHCP problems on version 8.0.1
Do you have in place an IP helper address pointing to your dhcp server under that layer 3 VLAN on your uplink switch ?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect
NTH
Hi Victor
Yes, there are IP helpers configured on the controller.
One of them is even on the same subnet as the controller itself.
Best regards
- Nicolai
