Contributor II
DHCP
Looking at the logs i found this:
Oct 22 10:33:25  dhcpdwrap[1820]: <202085> <DBUG> |dhcpdwrap|  No arp entry for ip address 137.52.242.221 eth1.1242
I thought the router is the one keeping the arp table whey does the wireless controller shows this error?
Thank you,
Enrique.
Re: DHCP
The controller has a ARP table. :)
#show arp
That will show you the ARP table.
Every device with an IP with have an ARP cache of some sort.
I'm not sure on the error though. What device is that IP assigned to?
Cheers
James
Cheers
James
Re: DHCP
I'm having this exact same issue. Any resolution?
Trusted Contributor I
Re: DHCP
do you actually have an issue, or is the issue only this mesage? could very well be something totally harmless.
you might want to open a case or share more information here so someone might help you out. first thing that comes to mind, do you recognize the IP, is it in your client subnet, controller, ....
