DNS Problem
I am having problems with a site that is not resolving DNS for WLAN clients (192.168.100.x), however, DNS is configured properly and works properly from the controller CLI.   I have serveral sites with identical configurations and have never seen this issue before.  Any advice would be greatly appreciated.
The site in question has a 650 controller running ArubaOS 6.1.2.5.  Here are my DNS entries from the configs (the x.x.x.x's are confirmed working DNS servers):
ip dhcp pool 172-AP-pool
 default-router 172.16.100.1
 dns-server x.x.x.x  x.x.x.x
 network 172.16.100.0 255.255.255.0
ip dhcp pool guest
 default-router 192.168.100.1
 network 192.168.100.0 255.255.255.0
Re: DNS Problem
Does the role that the clients are being place into allow DNS?
Do a "show user-table" and note the role for any of the users.  Then, do "show rights <role name>" and make sure there is an ACL entry that either allows all traffic or at least allows svc-dns (and is above any rules that might deny that same traffic... ACLs are processed in top down order - first match).
Re: DNS Problem
Can you reach the DNS server from the client with ping / traceroute? The server may be working but you could have a NAT issue. Was this site working previoulsy? I'm also guessing that the controller has a routable public IP. The clients are getting the correct DNS as well I assume.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
