Contributor I
Dashboard Monitoring
Is there any way to show more than a 15 min time span on the dashboard for usage? I am trying to pull some usage stats but can't figure out how to get a bigger time frame of data. Or is there a better way to pull usage stats than looking at the dashboard?
I am running  an Aruba 3600 with
Re: Dashboard Monitoring
You will need something like Airwave to keep all the historical information longer than 15 mins.
It's not possible to change that on the controllers.
ACCP, ACCX #817, ACMP, ACMX #294
