Trusted Contributor I
Dashboard doesn't display client, IP, or role
On a controller servicing only RAPs, I am unable to see the client, IP, or role when looking at the Clients dashboard.  All I see is a "--" entry in those columns.  If I go to the monitoring tab > clients, I'm able to see all of this information.  Any thoughts?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Dashboard doesn't display client, IP, or role
What version of ArubaOS?
6.3.1.4
Type "show keys" to see if you see the remote AP license on that controller
Yes, remote APs are enabled.
Please open a case.  I thought it was another bug involving licenses, but it appears to be a display bug.  Do you have campus APs on that same version with the same issue?
I dont' have any controllers running the same version, unfortunately.  Of the other versions I'm running, I am not seeing this issue with CAPs.
In case it matters, the version is 6.3.1.2 - whoops!  Still logging a ticket..
