  • 1.  Data Rates
    Posted Feb 27, 2016 01:11 PM
    what is different rates in each band
  • 2.  RE: Data Rates
    Posted Feb 27, 2016 01:26 PM
  • 3.  RE: Data Rates
    Posted Feb 27, 2016 10:26 PM
    Thank you for the reply .
    It's silly question .Why the same device sending in  different data rates ?
  • 4.  RE: Data Rates
    Posted Feb 27, 2016 10:29 PM
  • 5.  RE: Data Rates
    Posted Feb 29, 2016 04:05 AM
    Thank you for your great help . I have one question . Why always lower data rates must be disabled or recommended to
    disable
  • 6.  RE: Data Rates
    Posted Feb 29, 2016 04:12 AM
    It is not mandatory for lower rates to be disabled.  Lower rates are disabled typically to improve performance, because data at lower rates takes longer to transmit.
  • 7.  RE: Data Rates
    Posted Feb 29, 2016 10:59 PM
    If we disable lower data rate  and  the client can only can send and receive in that rate , the client will not  be able to connect to the wireless ?..If that is the case how can we know  the reason from the client and or from the controller ?
    Thank you
  • 8.  RE: Data Rates
    Posted Feb 29, 2016 11:06 PM
    Yes, and you will have a problem with that client if that happens.  The only way that you would know is if you change the rates back and it works.
  • 9.  RE: Data Rates
    Posted Mar 06, 2016 10:47 PM
    "clients can ignore the data-rates being announced by the access-point and the access-point will still accept the received data anyway"
    the above statement is true ?
    . I have done a test with a non-aruba ap and i found client is able to communicate with a disabled data rate
  • 10.  RE: Data Rates
    Posted Mar 06, 2016 10:49 PM
    It depends on the client.
