Database syc failed between Master and Master-Standby. VRRP working !!!
This thread has been viewed 35 times
  • 1.  Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 07, 2015 07:55 AM
    Master and Master-Standby database syncronization failed. VRRP is functioning properly.
     AOS on both controllers 6.3.1.13
    Master Configuration
    (Master) #show database synchronize
    Last manual synchronization time: Wed Oct 7 16:41:24 2015
    To Master Switch at 10.20.0.2: *** FAILED ***
    WMS Database backup file size: 0 bytes
    Local User Database backup file size: 0 bytes
    CPSec Database backup file size: 0 bytes
    Total size of Captive Portal Custom data: 0 bytes, 0 files
    Total size of Captive Portal Custom data last synced: 0 bytes, 0 files
    Synchronization took 30 second
    Last failure cause: Standby switch did not respond to the start request or is not ready
    80 synchronization attempted
    80 synchronization have failed
    Periodic synchronization is enabled and runs every 20 minutes
    Synchronization includes Captive Portal Custom data
    (Master) #show vrrp
    Virtual Router 20:
    Description Preferred-Master
    Admin State UP, VR State MASTER
    IP Address 10.20.0.3, MAC Address 00:00:5e:00:01:14, vlan 20
    Priority 110, Advertisement 1 sec, Preemption Disable Delay 0
    Auth type NONE ********
    tracking type is master-up-time, duration 30 minutes, value 20
    tracked priority 130
    Master-Standy
    (Standby) #show vrrp
    Virtual Router 20:
    Description Standby-Master
    Admin State UP, VR State BACKUP
    Priority 100, Advertisement 1 sec, Preemption Disable Delay 0
    tracked priority 100
    (Standby)  #show database synchronize
    Last synchronization time: Not synchronized since last reboot
    What should I do now ?
  • 2.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 07, 2015 08:03 AM
    On the current master, please post the output of "show switches"
  • 3.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 07, 2015 08:20 AM
    (Master) #show switches all
    All Switches
    IP Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    143.x.x.x IMH-MC3600 Building1.floor1 master Aruba3600 6.3.1.13_46575 up UPDATE SUCCESSFUL 0 20
  • 4.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 07, 2015 08:22 AM
    All Switches
  • 5.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 07, 2015 08:26 AM
    You don't have master redundancy configured properly. You should see two controllers from the master; the master and the standby
  • 6.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 07, 2015 11:24 AM
    Soory to say I disconnected the standby and remove the VRRP steup. Once I will make the setup again I will share the update.
  • 7.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:25 AM
    Dear Joseph,
    I have checked the vrrp configuration still the output is same. You are requested to please mentioned the steps which are useful to rectify the issue.
    Looking forward
     IMH-MC3600 is master
    (IMH-MC3600) #show vrrp 20 statistics
    Virtual Router 20:
    Advertisements:
    Sent: 161136 Received: 145
    Zero priority sent: 0 Zero priority received: 0
    Lower IP address received 145 Lower Priority received 0
    Tracking priority overflow: 0
    Advertisements received errors:
    Interval mismatch 0 Invalid TTL 0
    Invalid packet type 0 Authentication failure 0
    Invalid auth type 0 Mismatch auth type 0
    Invalid VRRP IP address 0 Invalid packet length 0
    VRRP Up timestamp: Tue Oct 6 17:24:52 2015
    Master Up timestamp: Tue Oct 6 17:24:55 2015
    Last advertisement sent timestamp: Thu Oct 8 16:17:25 2015
    Last advertisement received timestamp: Tue Oct 6 17:24:55 2015
    Current time: Thu Oct 8 16:17:26 2015
    Number times became VRRP Master: 1
    (IMH-MC3600) #
    (IMH-MC3600) #show switches
    All Switches
    143.x.x.x IMH-MC3600 Building1.floor1 master Aruba3600 6.3.1.13_46575 up UPDATE SUCCESSFUL 0 46
    (IMH-MC3600) #
    IMH-Standby) #show vrrp 20 statistics
    Virtual Router 20:
    Advertisements:
    Sent: 0 Received: 550
    Lower IP address received 550 Lower Priority received 0
    VRRP Up timestamp: Thu Oct 8 21:11:41 2015
    Master Up timestamp: N/A, not MASTER
    Last advertisement sent timestamp: never
    Last advertisement received timestamp: Thu Oct 8 21:21:16 2015
    Current time: Thu Oct 8 21:21:16 2015
    Number times became VRRP Master: 0
    (IMH-Standby) #
  • 8.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:29 AM
    Master redundancy has to be setup correctly for database sync to work.  That is different from VRRP redundancy.
  • 9.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:34 AM
    What information is required to create the  master redundancy and data synchronization ?
    Can you please mentioned the steps to create the master redundancy ?
    your cooperation in this regard will be highly admirable.
    looking forward.
  • 10.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:30 AM
    (IMH-MC3600) #show master-redundancy Master redundancy configuration:
    VRRP Id 20 current state is MASTER
    Peer's IP Address is 10.20.0.2
    Peer's IPSEC Key is ********
    (IMH-MC3600) #
    (IMH-Standby) # show master-redundancy
    VRRP Id 20 current state is BACKUP
    Peer's IP Address is 10.20.0.1
    (IMH-Standby) #
  • 11.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:33 AM
    If you type "show switches" from the master and you do not see the master AND the standby, master redundancy is configured wrong....
  • 12.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:38 AM
    looking forward.
  • 13.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
  • 14.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 07:59 AM
    Dear joseph
    for master redudancy we have configured th vrrp according to the steps mentioned in the link provided by you. But still the output is same. :(
  • 15.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:00 AM
    The key is to execute this, first on the master:
    config t
    master-redundancy vrrp <vrrp id>
    peer ip address <backup master>
    master-ip <backup master>  ipsec <key>
    Then execute on the backup master
    config t
    peer ip address <master>
    master-ip <master>  ipsec <key>
  • 16.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:14 AM
    Please find the below snapshots
  • 17.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:19 AM
    You should remove the master-redundancy configuration from the backup and re-apply it.  It is saying that the master ip address is the VRRP address and not the master's ip address.
  • 18.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:24 AM
    Can you please explain.... On the backup controller what changes are required ?
  • 19.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:26 AM
    Please open a TAC case about this.  I want to make sure you are not running into a bug.
  • 20.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:28 AM
    You are requested to please fill my configuration.
    Master controller vlan 20 ip 10.20.0.1
    Backup controller vlan 20 ip 10.20.0.2
    VRRP 20  ip address 10.20.0.3
    Key abc@2015
    config t
    Then execute on the bakcup master
    config t
  • 21.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 08, 2015 08:34 AM
    On the backup master:
    config t
    master-redundancy
    no master-vrrp
    no peer-ip address
    master-vrrp 20
    peer-ip-address 10.20.0.1 ipsec abc@2015
    If that does not work, please try using a key that does not have an @ sign.
  • 22.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 09, 2015 01:07 AM
    According to your guidance I matched all the steps with my current configuration. I also changed the key but the outcome is negative.
  • 23.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 09, 2015 02:26 AM
    hi
    please run the following two commands on the backup controller and paste here:
    show process monitor statistics
    show processess | include db,mys
    show log error | include dbsync
    you may be hitting known bug 116628, the output from the above commands will allow me to confirm it
    regards
    -jeff
  • 24.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 09, 2015 02:39 AM
    Please note your desired information in the attached file naming  ""Logs"".
    Attachment(s)
    txt
    Logs.txt   17 KB 1 version
  • 25.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 09, 2015 05:05 AM
    Please open a support case so that you can get help.
  • 26.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 09, 2015 05:33 AM
    +1 to what Colin just mentioned, time for a support case - the logs attached do not show any match with the known issue, so something else is going on.
  • 27.  RE: Database syc failed between Master and Master-Standby. VRRP working !!!
    Posted Oct 09, 2015 06:55 AM
    It looks like the keys in your VRRP 20 are mismatched:
    Invalid advertisement received for VRID 20, Mismatched authentication type
