Contributor I
Datapath failure caused controller reboot
I had a controller reboot a couple days ago and the reason in the logs was a datapath failure.  Has anyone seen or heard of this before?  I have a case open but wanted to get any input from the group.
Re: Datapath failure caused controller reboot
You need to contact support ASAP.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
can I ask what version it was and the controller please?
ACCP, ACCX #817, ACMP, ACMX #294
Contributor I
I'm running 5.0.4.0.  Support suggested upgrading to 5.0.4.6 or 5.0.4.9.  I don't see that happening in the near furture.  I'm at a large healthcare facility so getting downtime is difficult to say the least.
I guess I'll need to stay on 5.0.4.0 until it really becomes an issue.  Controller has been stable and has only booted once.
We've had this issue before and only an upgrade has fixed it.
I would suggest getting the process going to get the controller or controllers upgraded. If it takes a while at least the wheels are turning.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
