Dears help if you can in this issue?
I have full redandt controller archticture
2 masters 1 active 1 standby work very well
1 local with trunk port allowed vlans needed and cant't ping the VRRP IP but can ping the master 1 and master 2 on the smae vlan
and on the master I can ping the local
so why I should do to solve this ?
using trunk port and pass IPSEC makeing any issue?
I'm using controller 3200XM os 6.4
Re: Dears help if you can in this issue?
Is your VRRP session up?
Run:
show vrrp
Tim Cappalli | Aruba Security
running very well I have strange issue I use access vlan 20 and on switch 2 ports vlan 20 1 for the master and 1 for the local
and master can ping local and local can't ping VRRP whcih it is running very well
