Dedicated AP for specific users/machines
Hey all, moving into a new office space with my IT team. Basically I'd like to plug an AP into our office that only our team of users/laptops can authenticate to to gaurantee the quality of the connection. Is there a way to do that within the controller while still using the same SSID?
-GR
Re: Dedicated AP for specific users/machines
The simplest way is to place that AP in an ap-group that has your own custom SSID.  Make it so that only your SSID is broadcasting from that AP.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
