Frequent Contributor I
Dedicated VIA VPN - RAP controller ACL on its public interface
We've dedicated 7220 controllers for RAPs & VIA VPN services.
We brought up 2 interfaces.  One is used on an internal VLAN for management.  The other is used on a publicly accessable VLAN interface for communication to VIA Clients & RAPs.
What kind of ACL can I apply on the public interface to restrict traffic to only those needed ports & protocols (udp 500, udp 4500, protocol 50) for RAPs & VIA VPN clients to work?
Is creating an access-list like so the way to go?
conf term
ip access-list session RAP-firewall
any any any deny
any any svc-ike permit
any any svc-natt permit
& then apply this to my port.
conf term
interface gig 0/0/1
ip access-group RAP-firewall
Would this suffice or is there a better way?
TIA,
--Raf
--Raf
Re: Dedicated VIA VPN - RAP controller ACL on its public interface
That is exactly the way to do it!
Tim Cappalli | Aruba Security
Ended up adding ICMP for troubleshooting purposes.
ip access-list session VIA-RAP-firewall
  any any svc-https  permit
  any any svc-icmp  permit
  any any any  deny
When time allows, I'll update ICMP to only allow from my organization's network.
Also, since the access-list I created was a session based ACL, I needed to supply a type when applying it to the interface.
(controller) #configure terminal interface gigabitethernet 0/0/1 ip access-group VIA-RAP-firewall
% Incomplete command.
(controller) #configure terminal interface gigabitethernet 0/0/1 ip access-group VIA-RAP-firewall ?
in                      Apply access-list to interface's inbound traffic
out                     Apply access-list to interface's outbound traffic
session                 Apply session access-list to interface or Vlan
(controller) #show ip access-list VIA-RAP-firewall
VIA-RAP-firewall
Priority  Source  Destination  Service    Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
1         any     any          svc-natt   permit                           Low                                                           4
2         any     any          svc-https  permit                           Low                                                           4
3         any     any          svc-icmp   permit                           Low                                                           4
4         any     any          any        deny                             Low                                                           4
(controller) #configure terminal interface gigabitethernet 0/0/1 ip access-group VIA-RAP-firewall session
(controller) #
--Raf
