Contributor II
Dedicated subnet for access points?
We currently have a dedicated /24 subnet for our APs at each site. We have anywhere from 5 to 15 APs per site. I have heard that it is better to have the access points in the same subnet as the clients PCs.
Any suggestions either way? (I realize that from an addressing standpoint we are underutilizing the /24 but that is not much of a concern.)
Thanks.
Re: Dedicated subnet for access points?
You should mix your APs with clients for better rogue detection.
Tim Cappalli | Aruba Security
Contributor II
Thanks Tim, can you help me understand how this helps detct rogues?
The APs are able to see traffic on the wire to make MAC OUI correlations to rogue access points.
Contributor II
Got it, thanks again
Trusted Contributor I
as the question is answered im sure no one will mind my hijack.
do you feel the same for IAPs, would you also place those with clients?
