Default role for guests created via Guest Provisioning portal
Hi folks,
Ive made a Guest profile , for authenticated guest users.
Im using Captive Portal, and the local Internal DB. I'm also using the Guest Provisioning Page to create users. By default, these users get the 'guest' role. But I would like the users created with the Guest provisioning to get my customized guest profile.
I found a lot of helpless (and mostly old) posts to this topic, that's why I'll asking you by myself.
Aruba OS: 8.2
Thanks, Adrian
