Default values
Which default values you all guys change always and why?
For example
I normally change the value of the Max Associations to 25 or 30  which is per radio...
Why i change that ?
Because i think that sharing that small ammount of bandwidth is silly
What default values you recommend we should change and why?
Alternetworks Corp
Aruba
Re: Default values
Good question/dialogue.
Off the top of my head:   I always
a) change the IPS settings for Rogue Containment up to  Wired Containment = yes and Wireless containment = Tarpit-all-stations.
b) Add voice aware scanning, beside video aware scanning
c) add Qos Profiles for Fair-Access to all AP-groups
.. more to follow.
Re: Default values
Yeah i also always add the QoS for Fair Access on all the groups
Ill search the other values you said... to see where i change them....
It will be good if we can all share this information, as we will deploy better configurations :)
Alternetworks Corp
Aruba
Re: Default values
The scanning is under ARM profile.    The IPS is in the IDS category and Profiles.
Thanks for starting this thread!
Aruba
Re: Default values
BTW, another thought on modification of defaults:
I always modify the IPSEC retries in AP-system profile.   360 is too high for my liking in most scenarios.   I chop off the zero and go down to 36 right away.
With gather my thoughts with some more later today to minimize posting 1-2 at a time.
JF
Re: Default values
Let see if we can collect a lot of this and maybe we can create a list for everyone.
Like  a list of default values that are good to change to optimize the configuration!
Btw thanks i found the values you said... :)
Alternetworks Corp
Re: Default values
Jfernyc
Why would you want to reduce the time for this? which is the reason? i mean  this is the  Number of times the AP will try to create an IPsec tunnel with the master controller before the AP will reboot.
but why you would want it to be smaller to reboot faster? is there a reason fo rthis? im trying to undesrtand
Thanks in advance
Alternetworks Corp
Aruba
Re: Default values
I modify this setting as the default will 'hide' or 'mask' problems with the WAN more than I want them too.
My approach is that if the WAN is sick it ought to be addressed, not band-aided ;)
Aruba
Re: Default values
And two more for the 'list':
- Activate Dynamic Multicast Optimization (DMO) under Virtual AP
- Activate Band Steering, under Virtual AP
Re: Default values
Yes i always activate the band Steering
What about Multicast Optimization it is the one that says
Multicast Optimization for Video?
Alternetworks Corp
