Occasional Contributor I
Dell Aruba Ap-93h Wireless Access Point
Hey all,
I am searching the latest Aruba OS release for my Dell Aruba Ap-93h Wireless Access Points.
I am not able to find them on the official Dell Support Website:
http://www.dell.com/support/home/de/de/dedhs1/product-support/product/powerconnect-w-ap-93h/drivers
Does anyone know the product and may help me?
Best regards
ACCP, ACMA, ASCA (done) ACMP & ACSP (in progress)
Frequent Contributor I
Re: Dell Aruba Ap-93h Wireless Access Point
To clarify is this for DELL AOS or DELL Instant? (i.e. are your AP's managed by a wireless controller?)
thank you,
ACCP ACMP CWDP CWSP
thanks for the swift reply.
Its an W-AP93 with AOS 6.3.1.8-4.0.0.9_47220. The AP is controlled a virtual controller ...
Thanks!
Aruba
The 93H does not have an instant variety; it can only be controller managed; thus it will get is software only from the controller.
AMFX | ACCX | ACDX | ACMX
Hey,
Thanks again for the fast reply!
Just to verify: It is not possible to join an AP93H to an existing AP93 with a virtual controller running on it?
What kind of controller needs to be installed to get this running?
1x AP93 and 2x AP93H
You will need a physical controller as the AP93H does not support the Instant variety (there for no Virtual Controller).
http://www.arubanetworks.com/products/networking/controllers/
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
