Deploying Dual Bands APs
Okay i got a question
I have been reading the VRDs.  And i read in one of them that when you deploying this you have to be carefull because if you just do a site survey for a 2.4ghz coverage then you get the 5ghz issue,  which got less  coverage range.  Then you finish with a design of  5ghz island all over the place and the band steering cannot be as effective moving clients..
Now if i plan deploying a 2 band AP like a 105 should i do the site survey in 5ghz to not have this problem? or what you guys recommend i should do with this to do a proper site survey and making both bands work properly?
Alternetworks Corp
Re: Deploying Dual Bands APs
Survey for 5GHz, place the APs and let ARM adjust the 2.4GHz coverage accordingly.  The 5GHz radios will most likely keep their power high and the 2.4GHz will be somewhat less.
Thanks Olino
these VRDs got lot of useful info... im getting notice of some things im not taking in consideration that i should.   Great info with those  VRDs guys
Alternetworks Corp
Aruba
Surveying/RF planning using 5 GHz as the 'primary' requirement also has the side-effect of aligning you for an easier transition to future standards (e.g. 802.11ac) that will (re)use 5 GHz as well.
Hello i got another quetsion regarding this...
Does  wireless N on 5ghz band has the same indoor range than the N on 2.4ghz
I guess on 2.4ghz itas  250 feets...
Another question
When you got a client which just got 802.11g card and i got another clietn with wireless N card
And let say i got one access point  which is working on ht on wireless n
Does my wireless card on N  will have better signal than my other  wireless card with g?
Alternetworks Corp
Aruba
5 GHz 'anything' does not have the same range as 2.4 GHz 'anything' ;)   So no, Wireless 5 GHz N will not go 'as far' as Wireless 2.4 Ghz N.
At the same distance from an AP,  a Wireless N client will outperform the Wireless G client for sure.   Wireless N has a different modulation, and a different approach to multipath than previous standards.
JF
Thank you very much jfernyc
Your asnwers are really aprecited here!!
Cheers
Carlos
Alternetworks Corp
Aruba
Anytime Carlos.
Happy to assist.
JF
Hello again
Well i had some free time today at work(finally) and i was looking forward to test this.
I was testing with an AP 105
With my laptop with a program(inssider) looking the rssi value  to see how strong was the signal(my laptop got abgn card)
I could see that the 2.4ghz band was less stronger than the 5ghz band for some reason...
I was looking fordward to see the 2.4ghz stronger than the 5 ghz band but didnt happen
Is there anyhing im doing wrong? i mean i just did a fast config with the WLAN wizard...  but i dont know what im missing or what im doing wrong
Maybe i guess the ARM it adjusting that automatically  the power level of the 2.4ghz band as there are OTHERs aps around the building on 2.4ghz... and werll also there is NOONE using the 5ghz band.
Is there any command  in which i can see maybe the max power it can transmit and the power its using? or something like that? or something that lead me to see that 2.4ghz has more range than 5ghz? not that i dont bealive in what the document says it just htat i wanted to see it testing you know and see it working like im reading.
Alternetworks Corp
show ap active
