Detailed Data sheet of 7220 controller and Airwave
Hi all,
I'm wondring if someone have a detailed data sheet of mobilty controller 7220 and Airwave.
I need explicte specification that the MC 7220 supports like :
EAP-PEAP, EAP-TLS and EAP-TTLS
AES-CCM, TKIP and WEP
SSID and MAC based authntication
and more
Re: Detailed Data sheet of 7220 controller and Airwave
Here's the datasheet for the controller.
Here's the datasheet for ArubaOS 6.5.
Between them it should show you want you're looking for.
Cheers
James
Cheers
James
