Detailed exact dhcp option configuration for AP master discovery
Hello
what is the right dhcp configuration for AP master discovery?
thanks
Steffen
Re: Detailed exact dhcp option configuration for AP master discovery
DHCP Option 43 = <controller-ip>
DHCP Option 60 = ArubaAP
Tim Cappalli | Aruba Security
Aruba
You ask for "detailed", but don't say what DHCP server.
In general, the following should be configured:
  • DHCP Option 43 =  <IP of Controller>
  • DHCP Option 60 = ArubaAP
Details fo different DHCP Servers:
AMFX | ACCX | ACDX | ACMX
Thanks for the fast reply.
as i understand is the following correct?:
- the DHCP server receives the AP's DHCP request
- in this request is an Option 60 with value ArubaAP
- with this, the DHCP Server can filter this request and send a defined Option 43, which is configured in this filter
is this all, or must the DHCP Server sends the Option 60 back to the Access Point?
And when yes, is the question for what i must do this?
Steffen
Hi Steffen, As clembo said, what's the DHCP Server? Is it Adonis Blue Cat, Windows Server, etc?
#AirheadsMobile
Steffen
Hi Steffen,
Just trying to save you some time and frustration from our own personal experience - hence the importance of clembo's question about the DHCP Server Type/Vendor. We had spent several days of research (looking into 3 year old posts - Adonis BlueCat DHCP Option 43 for Aruba AP's) and working with Aruba TAC to figure out DHCP Option 43. We were able to get DHCP Option 43 working after reaching out to BlueCat Support - who actually had pre-made instructions for us. :-) - which also led to marking the earlier mentioned 3 year old post as solved.
I believe your understanding of the steps for DHCP Option 43 is correct. In regards to Option 60 being sent back to the AP - I suspect this is necessary as packet captures of our "Successful Implementation" of Option 43, as well as Aruba's KB Article Packet Capture show Option 43 AND Option 60 both being included in the DHCP Offer to the AP.
do you have specific instructions for Mikrotik?
We are using Mikrotik RouterOS v6.40.5 for DHCP Server
In Mikrotik there are options I'm not sure what Aruba nrequires..
The Mikrotik Wiki supplies the following information regarding DHCP value types :
  • 0xXXXX - hex string (works also in v5)
  • 'XXXXX' - string (works also in v5 but without ' ' around the text)
  • $(XXXXX) - variable (currently there are no variables for server)
  • '10.10.10.10' - IP address
  • s'10.10.10.10' - IP address converted to string
  • '10' - decimal number
  • s'10' - decimal number converted to string
Thanks!
Thanks!
I haven't seen instructions specific to Mikrotek. A packet capture of the DHCP offer would be helpful to confirm, but I would suspect the IP address response to be fine. Also, DHCP option 60 needs to be in the offer as well.
Charlie Clemmer
Aruba Customer Engineering
