Device Name on controller or airwave
Is there a way to see on the controller or airwave the device name of an ipad, windows and android devices?
What i have done so far was enabling AMON and also create a custom view on airwave to see the LAN hostname
I can see a FEW devices name... but i mean out of 100 i just see like 25 or 20...
Iam missing configuration? or is not possible?
Cheers
CArlos
Alternetworks Corp
Re: Device Name on controller or airwave
In ArubaOS 6.5 there is a parameter that allows you to use the mdns name as the computers username if the device is not using 802.1x. it is in the AAA profile.
If you are using any other ArubaOS, the network must support dynamic dns registration of DHCP hostnames into DNS. Airwave will then do the reverse DNS lookup to find out the hostname...
Collin
If the user is using mac authentication
It will override username if we use the aruba os 6.5? becuase the username is the mac address
Alternetworks Corp
I don't know if it overrides the username.
The question is, what do you want there?  if you are using clearpass, there is a way to return the username as a real username when you are doing mac authentication.  Do you want a username, a hostname or what?
I guess the hostname is okay on airwave
He just want to see the hostname for now...
He is getting clearpass but he does not have it yet...
He wants to see in airwave the hostname at least so he can locate the device... or at least know to who belongs that ma address...
Alternetworks Corp
So, he should run 6.5.x and enable Device Name as username in the AAA profile:  http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/802.1x/Device_Name_as_User_Name.htm#top
Collin
i configured this on the client
"If you are using any other ArubaOS, the network must support dynamic dns registration of DHCP hostnames into DNS. Airwave will then do the reverse DNS lookup to find out the hostname... "
This worked pretty good!
Thank you!
Alternetworks Corp
