Device discovery problem using snmpv1
  • 1.  Device discovery problem using snmpv1
    Posted Aug 29, 2013 01:54 PM
    Hi guys,
    I'm trying to discover other vendor wired switches with Airwave 7.7.3. The devices are 3com 4200 or 3com 4500 families with snmpv1 capabilities only. I run several Scans with different set ups on  Device Setup > Discover and Device Setup > Communication, while monitoring Airwave interface with tcpdump. The best result I got is snmpv1 request and response with no new device discovered.
    I also tried manually addition on Device Setup > Add and got snmpv2 request only.
    The command "snmpwalk -c community -v 1 ipaddress" on Airwave console works properly.
    Any other ideas?
    João
  • 2.  RE: Device discovery problem using snmpv1
    Posted Aug 29, 2013 02:00 PM
    João,
    I don't think we support discovery of those devices with scans.  I think your best bet would be to import them via csv on the Device Setup -> Add page.
    Dan
  • 3.  RE: Device discovery problem using snmpv1
    Posted Aug 30, 2013 10:14 AM
    Dan,
    If manual addition is not working for one device I don't see why it would work for many devices in a csv file. The problem is: Airwave uses snmpv2 by default to contact an added device. Device speakes snmpv1 only. I haven't found a way to change snmp version to snmpv1 on Communication properties of device.
    João
  • 4.  RE: Device discovery problem using snmpv1
    Posted Sep 04, 2013 04:55 PM
    According to this http://www.andovercg.com/datasheets/3com-4500g-switches.pdf
    it should support snmp v2.
    Are you on the latest firmware on that switch?
    EDIT
    Edited the link, had the 4400 instead of 4500
