Devices cannot connect to APs when in non-HT mode
I have a network of 7 APs all showing amber 5Ghz and 2.4Ghz LEDs. Normally they are green because they are set to allow HT mode. When this change to amber happened, devices weren't able to connect to the WiFi anymore. Shouldn't devices still be able to connect even when the connection is slow? Any help trouble shooting or getting these back to HT mode is much appreciated.
Re: Devices cannot connect to APs when in non-HT mode
Type "show audit-trail" on the commandline to see what command you issued created your issue.
Outside of the association issue...is there a reason you are disabling HT?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
