Contributor I
Devices on a WMM Enabled VAP
I  have a situation where we have new Avaya Wireless phones that have to have WMM enabled on the SSID. The problem is that I have other Avaya phones on this SSID that are not WMM enabled. By enableing the WMM traffic management  profile on the VAP will it cause a problem with the non WMM devices?
Re: Devices on a WMM Enabled VAP
When 802.11n or 802.11ac is "turned on" by default WMM is on, as well.  Enabling WMM traffic management *should not* cause trouble with other clients, but test, test, test to make sure..
Contributor I
That's what I plan to do - test, test, test. Thanks Colin.
