kmd
Contributor I
Dhcp Relay on vLan Interface?
Hi.
I am trying to put dhcp relay on a new vlan. Vlan 500, but I dont know what commands to use. I already have seven vlans using it, but someone else configured the router.
I tried: (Aruba-DataCenter-1) (vlan "500") #ip helper-address 10.1.10.20.
And:
(Aruba-DataCenter-1 (vlan "500") #dhcp-relay- DHCPRelay1
But it didnt like that.
Any help is greatly appreciated.
Here is my show interface for vlan 500 and vlan 400
(Aruba-DataCenter-1) #show interface-config vlan 500
vlan "500"
Parameter                   Value
Interface OSPF profile      N/A
Interface PIM profile       N/A
Interface IGMP profile      N/A
Directed Broadcast Enabled  Disabled
Interface shutdown          Disabled
mtu                         1500
IP Address                  192.168.50.1/255.255.254.0
IP NAT Inside               Disabled
IPv6 Address                N/A
IPv6 link local Address     N/A
DHCP client                 Disabled
DHCP relay profile          N/A
Interface description       N/A
(Aruba-DataCenter-1) #show interface-config vlan 400
vlan "400"
Parameter                   Value
mtu                         1500
IP Address                  192.168.40.1/255.255.254.0
IPv6 Address                N/A
DHCP relay profile          DHCPRelay1
Re: Dhcp Relay on vLan Interface?
You need to configure a DHCP relay profile and then apply the profile to the interface.
Tim
Tim Cappalli | Aruba Security
kmd
Contributor I
Hi Tim,
Thanks for your quick response.
I have DHCPRelay1, as a DHCP Profile, it is applied to the other Vlans, by a consulting company. But, when I try to apply it to the vlan500 interface, it rejects it. Can you tell me what command should I be using to apply DHCPRelay1 to vlan500?
I really appreciate your help. Clearly, training classes are in order, on my end!
Interface vlan 500
Dhcp-relay-profile
Tim
kmd
Contributor I
Tim,
Thank you so much. Again, you helped me move forward.
