Difference between Model number and product number
I am in bit confusion in identifying what is the Model number and product number for Aruba APs and controllers.
Am using AP 135 Access points and A3400 Controllers. Can anybody help me identifying the Model number and Product number?
Jayanth P L
Re: Difference between Model number and product number
Usually model is the "generic" name like AP-135 or AP-134 and part number is the specific device with regulatory domain. For example IAP-135-US.
For the contollers, no country designation indicates an unrestricted controller.
Tim Cappalli | Aruba Security
