Difference between local and branch controller
Hi experts,
I would really appreciate it if someone can point me towards where to find the difference between local and branch controller.
Thanks in advance!
Re: Difference between local and branch controller
Branch controller has the following capabilities:
- Zero touch provisioning
- WAN Health Check / Auth survivability
- All the config will be pushed from the Master controller (7200) including VLANs , Interfaces, NTP , syslog, profiles,etc ) using Smart Branch Config
- 70xx series running 6.4.3
- Policy based routing
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Branch%20Office/BoC.htm
Local controller:
- Master pushes the config except for VLANs, Interfaces , NTP , etc those are configured locally on the local controller
- No zero touch config
- No WAN optimization features
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect
