Different controller on same network
Network with Aruba 7030 Controller Can we add a smaller controller to the same network say 7005, will it be managed centrally by a single console
MVP
Re: Different controller on same network
[ Edited ]
Yes, you can configure oen controller as master and the othe as local for example.
Then all operational configuration must be doen on the master controller and will be synced to the local.
With this seytup you can use the capacity of both your controllers.
Koen (ACMX #351 | ACDX #547 | ACCP)
Aruba
You should also be able to use Airwave if you want to keep both controllers standalone or masters
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
