So you're seeing more devices associating on different radio types than per SSID. Isn't this normal?
I would imagine clients are balanced across the radios to some extent. E.g. A dual band client will sometime be on the 2.4GHz radio and sometimes on the 5GHz on depending on your Wi-Fi config.
