Dimensions rack mount kit AP-130-MNT-W2
I have 700 AP135 to install, i would like to prepare the project before having the AP and Mounting kit.
The document Aruba AP-130-MNT-W2 installation guide has some informations (how to install it) but have no information about dimension.
someone has it  (HxWxD) ?
regards
Jerome
MVP
Re: Dimensions rack mount kit AP-130-MNT-W2
Only info i found for you  is regarding the AP unit itself..
Hope it will help u to fit the AP/mount (usually the mount isn't much bigger in the width from the AP and it shorter in the height.
Me.
thanks for your answer.
But i will like have  the depth. I would plug a secure cable. The rj45 connector is slightly longer than  normal connector (I do not have the exact size yet) and i will be sure this cable is good for the rack mount kit.
Jerome
Aruba
A mechanical drawing of the AP-130-MNT-W2 box is attached (plastic part only; slider and spring not shown).
You only have about an inch clearance behind the RJ45 connectors, which means that you'll need to use low-profile plugs to leave enough space to allow for the cable bend radius. It will be very difficult (impossible?) to use cables with the bigger molded-on RJ45 plugs; the expectation is that the cable is cut at the AP and terminated with a crimped-on plug.
Hope that makes sense.
/Onno
/Onno
