Regular Contributor I
Directional Antenna dB Question
By adding an ANT-17 to an AP-124, would the antenna's gain noted in its specifications generally be the dBi I should plan for in deployment?
Aruba
Re: Directional Antenna dB Question
Yes, that's correct. When provisioning the APs in AOS, the antenna gain number (in dBi) from the datasheet should be used to make sure the SW correctly calculates, sets, presents and limits the transmit power for the AP. All RF power numbers in the Aruba software are in terms of "EIRP power", which includes the antenna gain.
/Onno
