Disable Management over Wireless for IAP-105
 I'm sure I'm missing something... we have some older IAP-105 WAPs that we're using to change our Wi-Fi and I'm trying to find the option to disable the ability for anyone to connect to the management IP over Wi-Fi but I can't see to find it in the GUI.  Version is 6.4.4.4-4.2.3.2_54910.
 Any help would be appreciated.
 Thanks.
