Occasional Contributor I
Disable Stateful Firewall completely for a SSID/Virtual AP?
Is it possible to disable the Firewall Functionality for a single SSID/Virtual AP completely (individually)?
(Currently Running 6.4.4.16)
Re: Disable Stateful Firewall completely for a SSID/Virtual AP?
- You would have to configure the assigned role to have only the "allowall" ACL
Roles are configured under Configuration> Wireless > Security> Access Control.
Having a firewall policy is an integrated part of the infrastructure and it cannot be just removed; it must be made more permissive.
Colin Joseph
Aruba Customer Engineering
Hello Colin,
thanks - ok, that does what i was looking for!
Of course you normally wouldn't want to do so in general.
But i want to create a completely "open" SSID, for an isolated VLAN that's only tunneled through the network to a dedicated gateway with no other connections possible whatsoever (also inter-user-traffic in that net is being denied).
I only care about bandwidth / usage, any further security issues (access-control, firewalling etc.) have to be dealt with behind that gateway (and they are)!
