Disable roaming wireless
hi
 Is it possible to disable roaming for particular SSID ?
Re: Disable roaming wireless
Hi, why are you looking to disable roaming? I assume L2 roaming?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Only real way I know to effectively prevent roaming is to have unique SSID per AP; this has numerous side-effects though.
What goal are you trying to achieve?
